Hi from Ross-on-Wye
Hi from Ross-on-Wye
  • #285082
    Roger Clark
      @rogerclark
      Hi everybody, having just retired I treated myself to a mini lathe and mini mill from SPG Tools. I used to use my fathers Myford super 7 long bed to make a Tich, sadly no longer have it or room for a super 7 hence the mini tools.
      Im looking at building the M E Beam engine as my main project if I find the m e articles on the build.
      Roger
      Roger Clark
        @rogerclark
        #285109
          Hello Roger
          Here's a link to an online ME index: http://www.groundlevel.demon.co.uk/me_index.html
          The beam engine was revised a few times, so make sure you find the description that matches your castings.
          You will need to find someone with a lathe of greater centre height to do the flywheel.
          Roger Clark
            @rogerclark
            Hi Neil,
            Thanks, I'm probably buying the castings from Reeves, mainly because I haven't seen them elsewhere, not sure about the gears though, seem rather expensive!!
            Thanks for the link, I guess I'll load and merge them and do a search and see what comes up.
            I have options for the flywheel as there is a club in Hereford.
            Roger
            #285256
            Howard Lewis
              @howardlewis46836
              Welcome aboard!
              You will learns lots on here, about all sorts of things.
              If it is not too far to drive, have you thought of joining the Hereford Society?
              They are a friendly crowd, and will be very helpful, I am sure.
              I am not a member and so have no axe to grind here, since I live in East Anglia. Only know them from visiting when volunteering at The WaterWorks Museum, which is next door.
              #285259
              Roger Clark
                @rogerclark
                Thanks Howard,
                Good to be aboard
                Hereford is 15 miles away so will be paying them a visit with a view to making it a long term relationship.
                Going to be a busy retirement, no time for the SWIMBO list
                Roger
                #285935
                Craig Shaw 1
                  @craigshaw1
                  Hello Roger and welcome to the forum!
                  I live in Hereford and plan to join the Hereford crew shortly. In the meantime I have a larger lathe in a workshop you are more than welcome to use when you progress in your project. The doors are always open and the kettle is always on! PM me if you are passing Hereford.
                  Craig
                  #285936
                  Roger Clark
                    @rogerclark
                    Thanks Craig, will be ringing Wally tonight to see what days/evenings they meet.
                    Will keep in touch
                    Roger
