Welcome to a useful and rewarding hobby.
+1 for what Noel says.
Now that you have a lathe, all sorts of new vistas will open up for you.
Your choice of a SC4 sounds good to me, based on the spec and the little that I’ve seen of them.
Having been a long term customer of Arc Euro Trade, who import them, if you have a query, or want accessories, go to them Ian and Ketan will be most helpful.
If you are new to lathework, an alternative book that would help is Stan Bray’s “Basic Lathework”
.(Workshop Practice Series 45)
As you gain experience, you may find a need for other books, if only as reference books.
A set of Zeus Charts will be a good investment. I still frequently use mine, bought in 1958!
Take time to become familiar with the machine. To start, learn how to rotate a handwheel steadily, using both hands (Although the SC4 has power feed in both planes)
Practice just cutting metal, to get a feel of different depths of cut, and then different feed rates. (If you are roughing out, you can use higher feeds, with finer feeds for the finishing cut.
Make your mistakes on mild steel, rather than castings which will be expensive, or items that cannot be replaced.
You may want to use carbide tipped tools, but you can’t sharpen them, other than with a diamond wheel. High Speed Steel can be ground, and into shapes for which no carbide tip is available.
Then, start making simple tools for yourself. This will give you practice, and give you confidence and satisfaction with every successful product. And you will have items that you can use for years afterwards.
My hobby horse is to make a Centre Height Gauge for setting tools, first.
Unless it is set on centre height, no tool will cut properly!
Don’t be afraid to ask!
If I can help, just PM me with an E mail address and i will give any advice, (FWIW) and send any pictures that might be useful. Bear in mind that although a retired Engineer, I an not a time served machinist, and there are people on here who are far more skilled than I
Howard,
