Posted by Jacky Young on 30/11/2016 12:14:06:
This is driving me nuts, I appreciate all the advice and opinions above, thanks for the input.
The shiny 3 in 1s look good but I think the machines would flex all over the place under stress.
Anyway stuck on the net and the wife's not happy
Jacky
Sorry to pick you up on this but, Flex?! seriously? have you seen the net weight of the CL500 perchance?
Not only do i defy anyone to lift 130kg lathe with their own strength, but any sturdier than that webbed bed casting and you're on the industrial scale of things.
You can't see it in the picture but the underside is completely ground flat too. The dovetails on the bed are nice and smooth.
I'd agree i wouldn't want it as my main mill, more an aside, but still the above stands. Not many pictures i'm afraid but so far the biggest and baddest stuff i've turned with this lathe it handled no problem, hardened steel 30mm shafts over 6" (using ceramic tipped tool) and widest being 6" backplate iron castings.
The Cl430/500 can certainly take it's weight on the turning side, the mill is powered by a dogclutch so you're getting the same grunt from the same motor so presumably given the setup is sturdy the milling power is just as good.
You're obviously not going to get anywhere near the same amount of purchase for movement as a dedicated mill gives you.
Also if you want evidence that the mini lathes are worth while, check out mike cox on weebly or Neil's stuff on here or in the magazine, they had no problem getting steel projects done using them properly.
Sorry to go on a bit, but i think like i warned earlier, regurgitating too much information on the pros and cons can be tiring and eventually you have to chose what feels right for you. Alot of problems on here regarding lathes can be genuine one offs or simply down to a poor setup rather than the machine itself. You don't often get to hear the good stories because they aren't told as much!
PS. i'm surprised nothing from warco has taken your fancy? That could be a viable alternative.
Michael W
Edited By Michael Walters on 30/11/2016 14:06:10
