John, thanks for the reply – only after I clicked send did I realise that 1 – (2 x 0.125) was 3/4 and would hence fit in the internals of the box section.
Thanks for clearing up my question regarding support at 2nd shaft. I can’t see the slotted link at the rear and assume in missing something with regards to how the rear of the subframes / springs attach. (I can picture it in my head, but logic is suggesting that the rear most end of the rear spring will need the eye reducing in width.)
As for 4 / 5 leaves – The drawing shows 3leaves for the rear springs and 4for the front (?)
Sounds like you’re a fair way along with your model. I’m gonna get the chassis started on mine just after the new work bench is finished (Christmas Project!)
What is troubling you with the boiler? My boiler is about 70 % complete. Made in copper instead of steel. 10gauge being my choice. (since we don’t need to equate for wastage!) It’s a fairly lumpy kettle, but with careful forethought and kawool and brick hearth setup on the workmate it’s going together quite nicely. All done outside, so won’t be doing much to the boiler now until the weather settles.
My Thoughts at the moment are whether the make the boiler ends flat as per drawings (but obviously flanged for solder area) or whether to try and make them dished as per gas bottle ends. Train of thought being if I make them dished I wouldn’t need the stays.
I’m quite looking forward to getting on with the main tractor, but can see many little alterations to the drawings – several things look to be sloppy. Like the circular die blocks – easy to make, but I can see the single point contact in the links giving an annoying clicking through wear after relatively short run time.
Anyway, I should be in the workshop, cutting metal, not at the computer!
Merry Christmas
Pete
