Hi
Hi
  • #574399
    Drew Mason 1
      @drewmason1
      Hi eveyone
      Very pleased to join the forum and in need of a little help (i will post when i've found the correct area). I am new to the wonders of lathery and have been enjoying myself immensely. I subscribe to Modedl Engineers Workshop which is just a fabulous read.
      Just wanted to introduce myself before begging for help now my Sieg SC3-400 has died!..
      So hi to all
      Best regards,
      Drew
      Drew Mason 1
        @drewmason1
        New member Sheffield
        #574457
        Brian H
          @brianh50089
          Hello Drew and welcome. I'm afraid that I cannot help with your Sieg but I'm sure that someone on here will be able to help.
          I'm about 20 miles South of you near Mansfield.
          #574466
          peak4
            @peak4
            Hello and Welcome; looks like I got out just in time. devil
            (recently retired from Sheffield-Crookes, and moved to Buxton).
            Shout up if you need any specific Sheffield contacts or info.
            Bill
            #574470
            noel shelley
              @noelshelley55608
              Welcome Drew, I cant help you with the sieg but there will be maNY HERE WHO CAN ! Good luck Noel.
              #574473
              Ian Parkin
                @ianparkin39383
                Welcome Drew from me in NE s7
                #574474
                Howard Lewis
                  @howardlewis46836
                  Welcome to the Forum
                  There will be at quite a few others on here who can help you.
                  What were you doing when it failed?
                  Not trying to take 2 mm cuts with a high feed rate, I hope! It is a small 400 watt brushless DC hobby lathe, not a three phase 10 hp 21" industrial monster.
                  Starting from a totally simple base
                  1 ) Is the fuse in the plug intact? (Assumes that power is available at the socket )
                  IF NO, replace
                  2 ) Is the fuse on the machine intact? If NO, replace. If you have produced a fault on the board, it may blow again., and then you are in deeper trouble.
                  3 ) Does the motor run? If Yes then the problem is mechanical in the drive line, (belt or gears )
                  If NO, THEN you start investigating the board and the motor., and need specialist advice.
                  There is a Model Engineering Society in Sheffield. Look it up on Google, and join. You will find it useful when you have your lathe up and running again. You will learn a lot, just by talking to and listening to the other members.
                  #574610
                  Drew Mason 1
                    @drewmason1
                    Hi all and thanks for your kind messages.
                    Howard u6 chip now has a hole in it and cap and diode next to it charred..
                    Thanks for the advice
                    Best regards
                    Drew
                    #574621
                    Harry Wilkes
                      @harrywilkes58467
                      Welcome to the forum
                      H
                      #574637
                      Howard Lewis
                        @howardlewis46836
                        That sounds rather terminal!
                        Sounds like you need to talk to Ketan about a replacement board!
                        Take a look on the Arc Euro website for prices and availability.
                        #574645
                        clogs
                          @clogs
                          I know nothing of these tiny lathes but would it not be better to upgrade to at least 240v motor or even a 3phase with a VFD…?
                          no idea if that s the correct term…..
                          small motors and electronics……..grrrrrr….
                          arn't they always in trouble this DC stuff………?
