W E Sykes, my employer back in time (1910 – before my time… to avoid the wags), invented a machine to cut double helical gears. Previous methods required a gap as the helical gear shaper cutters couldn't meet at the same position.
As Bazyle points out, they avoid the axial load produced by meshed single helical gears. The avoidance of a central gap was said to make stronger gears. The rotation had to be such that oil, being virtually incompressible, would not be trapped in the 'vee' of the teeth.
The gears were usually used for large reduction gears, such as turbines.for electrical generation, possible ships. We made the machines, not the gears. The company had examples of a one tooth helical gear meshing with another with multiple teeth, to show the continuous contact at all positions of rotation.
Bill
