I am assembling a Mamod loco following words and music by Ian Jowett and others and he mentions smearing non moving parts with Green Hermatite. Not struck the word before and assume it is a form of gasket goo. Hope somebody can confirm or stop me before I wreck the wee loco
As said green is a thick(ish) varnish like sealer, intended for joints that will not be dismantled. Have not seen it for years An oil based varnish or paint can be used instead ,not modern acrylic or cellulose. I liked the old green stuff.
Just a couple of quick ones :- Handlebar grips just need a slosh of petrol and then a quick push on. Using cement is a waste of good money. they are still made out of rubber aren't they? Good gaskets don't need gasket goo. To much sealer is worse than to little. OK 3 quick ones.
And if you do use gasket sealer, the spray can Hylomar applied thinly and allowed to dry before assembly works a treat on most applications other than head gaskets on IC engines.
