Herbert Type v drilling machine
Home Forums Manual machine tools Herbert Type v drilling machine
  • #644480
    Neil Greenaway
      @neilgreenaway71611
      Hi,
      Would anybody know if what was recommended for lubrication on the high/low and feed gearboxes in a Herbert type v drill? I have one which has been "repainted" at some stage I'd say about 40 years ago and some fixings overpainted so I'm not sure there are fill/drain plugs on the main gearbox (probably about 70year old?). The feed gearbox has spring lid oil cups so I'd reckon this is a total loss type which leaks whatever you drop in.
      Its a smashing machine, and runs very smooth and quiet with loads of torque.
      I'm aiming to look after it and hopefully it would run maybe another 70 years.
      Thanks
      Neil Greenaway
        @neilgreenaway71611
        #644483
        Emgee
          @emgee
          I used grease in the quill downfeed via the nipple provided, the table feed box was removed as some gears were missing, never did replace them but used it manually.
          Emgee
