Having made a couple of Hemingway kits – a boring-bar set and a tool-&-cutter grinder, I can say this won't be a "weekend" task. Some months of weekends would be a fairer guess.
As it's not a flat-packed hacksawing-machine, but a set of castings, bar-stock and other components there will be quite an amount of machining to do.
Hemingway seem to design their kits and instructions to allow using simply a Myford 7- series lathe with vertical slide, and a bench-drill; which is probably all that some of the original designers of these machines had. So if you have a vertical milling machine as well, it will enhance and accelerate building these kits.
Their drawings and instructions are clear and comprehensive, using both orthographic and coloured 3D images; though you may need alter their suggested methods a bit to suit your machine-tools etc..
(As a very simple example of the last point, I did not make the angle-steel jig as suggested for guiding the stamps for numbering the grinder's protractor scale. I used an old Vee-block instead. )
