Posted by Nathan Adamson on 20/10/2021 10:45:52:
I assume it’s the control board, I’ve also read that these have torque issues with earlier control boards.
Does anyone know
a) Was there a specific list of serial numbers for the dud controllers so I can avoid this
b) Where do I get a new board from
c) Can they be repaired and also have the torque issue fixed?
Thanks
Nathan
It all depends on the age of the machine, combined with user related issues.
The first SX3 was sent to ARC for testing over ten years ago. It had serious torque issues. During tests under a controlled environment wearing a gauntlet – not something I would suggest anyone to do – it was very easily possible to stop a running spindle at low speed. This was due to incorrect programing of a chip for torque on SX3 and SC4 lathe. ARC refused to take on said machines. They still appeared on the market trough certain official dealers, as well as unofficial dealers. So this explanation deals with some of the machines which are over 10 years old.
ARC started selling SX3 only after above problem was fixed, probably around 9 to 10 years ago. Whilst these problems were fixed, some issues appeared with control panel for a short time, which were fixed. Then came issues with the e-stop, which was a combination of E-stop switch performance in itself, as well as user related issue, whereby some users were using the e-stop to stop the machine, instead of the on/off switch. Too much use/abuse of the e-stop switch resulted in various faults developing. Unfortunately incorrect training offered by a particular distributor – promoting the incorrect use of the e-stop in the training course – also contributed to this problem.
The above machine related issues were dealt with and ironed out in the majority of cases over 7 odd years ago, and it is rare now a days for us to come across this – machine related issue. Due to its positive torque performance over time, this was one of the first machines for which ARC provided warranty around 5 years ago for hobby as well as light industrial use for an individual user. For most smaller SIEG machines, ARC provided warranty for hobby use only. The SX3 still remains one of the most popular SIEG machines in the ARC product range.
With reference to your second hand purchase, it is difficult to say if the fault you have observed results from a machine related issue or a user related issue. If it is a very old machine with the original poorly programmed board, perhaps the original user didn't know any better, or, if the machine was used/abused to deal with work beyond its capacity/capability, fault/s developed…. as was the case with Paul Lousick's SX3 to which he refers in his post… as far as we are concerned.
So, it is wrong to paint an 'underwhelming' brush on the SX3s without really knowing what is the real story with the second hand machine which you have purchased… probably at a knocked down price…. as many in your situation do.
Age of the machine is determined from the serial number. in the case of the SX3, this is to be found on top of the column casting. You will need to get on top of a stool and then look on the top. We can figure out the built age from the serial number.
Then you need to look at this page link on our site to figure out all the things you will need and ask for said parts from the SIEG distributor in Australia – if he can supply.
Nobody really knows what is the cause of your particular fault. To the best of my knowledge, the board is not repairable.
Ketan at ARC.
