After scanning the long list of topics I have opted for this one.
I decided I should either scrap my old Jones VX561 domestic sewing machine or replace the motor, which appeared to have failed. However, dismantling the “three prong socket” into which the power lead is plugged revealed an apparently burnt out capacitor; the separately located motor seems itself to run OK when connected directly ie without the capacitor.
I assume that the capacitor is either for starting and/or running the motor and nothing to do with the built-in machine light.
The capacitor is marked "nichicon JAPAN" and is rated at 0.05 uF 250 VAC. Being situated inside the socket on the machine, it needs to be no larger than the existing at about 1" long by 1/2" diameter.
I have tried in vain to locate a suitable replacement and am wondering whether the technology has moved on to the point where such capacitors are no longer available (my electrical knowledge is minimal).
Can anyone suggest a source for a replacement, please?
