Help wanted, calling all Unimat SL owners
Home Forums Workshop Tools and Tooling Help wanted, calling all Unimat SL owners
  • #638183
    Graham Meek
      @grahammeek88282
      I was wondering if there are any Unimat SL users on the Forum.
      I am making a tailstock support for my Proxxon/Emco Dividing Attachment set-up.
      I was hoping to use the same size centre mounting diameter at the Unimat SL, which I think was 7mm or slightly over.
      Can someone confirm this size for me?
      Gray,
      Edited By Graham Meek on 18/03/2023 11:05:29
      Graham Meek
        @grahammeek88282
        #638185
        Thor 🇳🇴
          @thor
          Hi Gray,
          Mine is 7.15mm measured with a cheap digital caliper.
          Thor
          #638188
          Tim Hammond
            @timhammond72264
            I've just measured my dead centre using a M&W micrometer and got a reading of 7.18 mm.dia. The shank on my revolving centre measured 7.19 mm. HTH.
            #638190
            Andy Carlson
              @andycarlson18141
              282.6 thou on my Imperial mike… which is 7.18mm. Mine are a pretty easy sliding fit inside the head/tailstock bores.
              #638211
              Hollowpoint
                @hollowpoint
                Just tested mine, they tally with everyone else's measurements.
                I have 2 unused dead centres, the shanks are 7.185mm and the shank on a as new revolving centre 7.190mm. Measured with a M&W micrometer which I know is very accurate. 🙂
                #638215
                Graham Meek
                  @grahammeek88282
                  Thank you all for responding to my request, I had the figure of 7.2 mm stuck in my mind, but it always pays to check.
                  Gray,
