Posted by not done it yet on 04/10/2021 22:07:29:
Maybe set to the desired angle and secured in position via whatever was fitted to it?
No ideas apart from that initial thought.
Upon dismantling the base it's quite clear the two studs do lock off rotation. If I'd looked more carefully I would have noticed the studs were partially threaded and the nuts were at their limit (thus not locking off). But adding some drilled flat across the studs I can confirm it locks solid.
