“It’ll be threading a 1.25″ bar to 1 1/16 x 18 for a length of around an inch. Then reaming the inside to a set dimension maximum 3″ in length with maximum 0.600″ diameter.
The other times will be me just practising and having fun, most likely will aluminium and brass.”
Am I missing something?
If the part looks like the above, and is 3″ long by 1.25″, bored 0.6″, and threaded 18tpi at one end, then it’s well within Chinese mini-lathe capability.
Stainless steel tends to work-harden if the cutter is allowed to rub, a mistake easier to avoid on a powerful lathe. But certainly possible to turn stainless with a mini-lathe. Or any other lathe that can hold that size in the chuck. If the thread is standard UNF or BSF, it could be die cut so a plain lathe would do.
messy: in ye olden days lathes were bought as a once in a lifetime investment, making it advisable to spend to the max on the very best tools available. A major decision, filled with angst. Not so today: we can start with an affordable lathe, learn on it, and, having been educated, move on if it turns out to be not good enough.
