Thanks to all for the continuing input and advice. This is just a holding update because I haven’t had chance to progress matters as I had planned.
I have, however, established that a ‘shim’ cut from ordinary typing paper reduces the run out to 4 thou at 4 inches from the chuck, which is very much better than previously.
I need to try Hopper’s jaws/taper concentricity test next. Unless that throws up a major anomaly, perhaps unlikely given the paper shim result, I am going to try easing the taper slightly as suggested.
I don’t think I’m adept enough with a bearing scraper to risk that approach so I’m going to see if I can make a lap, as Macolm advises. I’ve never yet cut a taper on the lathe [at least not intentionally] so that should be a good learning exercise.
I’ll post again once I have some progress to report.
JR
