I'd vote for Comsol as well. It only melts at 300 degC, but that's plenty enough for cylinders. Being a higher melting point than 60/40 it retains more strength at higher temperature.
The only problem you might have with Comsol is that it requires a different flux from 60/40 and pure tin. Most leaded and lead free fluxes only just make it to 230 degC. For Comsol you need "Bakers Fluid" which is otherwise described as a Zinc Chloride flux.
Don't get the flux on anything other than the work. It rots just about anything it comes into contact with, and is a devil to get rid of. It will dilute in water. On steel it somehow penetrates into the surface, such that reoccuring rust appears where none did before.
