Help needed – Find hollow tube with interior screw thread
Home Forums Introduce Yourself – New members start here! Help needed – Find hollow tube with interior screw thread
  • #464012
    Steve Shaw 5
      @steveshaw5
      Hi Guys,
      Thank you for accepting me to your forum.
      Can anyone help me source in the UK small hollow tubes with interior thread?
      The tube needs to be approximately 12 inches long with any interior thread below 1 inch.
      Many thanks
      Steve Shaw 5
        @steveshaw5
        #464062
        JohnF
          @johnf59703
          Steve, you need to give a little more information, what material is the tube, whats the O/D, what is the bore size, what thread specification do you want/need — size & pitch if not a standard thread. Finally you quote " interior thread below 1 inch" do you mean the depth of the thread is to be at least 1" or greater ?
          #464063
          Jeff Dayman
            @jeffdayman43397
            As JohnF says we do need some more info. Depending on sizes needed, I would try a lamp supplier or an electrical supply firm. Various sizes under 1" are available where I am (Canada) to be used as "drops" to suspend electric light fixtures from ceilings. Definitely available in USA as well. They may be available in UK or other parts of world too.
            #464074
            old mart
              @oldmart
              Welcome, Steve, you have certainly started with a difficult one. The electrical fitting pipes all seem to be externally threaded. Making one of several sizes would not be hard for me, but during lockdown, I have no access to the required tools. A suitable tube would have to be tapped right through using a tap with an extension silver soldered on to it. As usual, there are some sources in the USA, but getting anything sent to the UK is extremely difficult and expensive.
              #464078
                This is the type of tube Jeff mentions, M10 x 1 is a common light fitting thread
                #464080
                Martin Connelly
                  @martinconnelly55370
                  There is a UK supplier of something that may suit Flamco
                  Martin C
                  #464117
                  Steve Shaw 5
                    @steveshaw5
                    Thank you everyone for your help, I have now managed to find what I need
