Have we got to the bottom of this yet? By which I mean – on the basis of this additional info from Matthew – I don't think the input gear is the only consideration.
If Matthew's diagram of gear numbers is correct, there are some odd looking gear ratios in the gear train.
My understanding – based on my old MK1 S7 – is that the final gear is 72 teeth, the two idlers are each 51/17 (ie 3:1 each giving a 9:1 reduction for the fine feed, a 1 : 1 straight through for the threading application) and a 24T (not 30T, thanks Brian) on the mandrel as the input gear.
As I say, if Matthew's hand written sketch is correct those gears won't do what we're expecting.
The 45 T gear as the first driven doesn't look right, isn't this a 30 with the 24T (mandrel gear ) compounded to it. Does this iteration of the S7 have a 45T gear on the tail end of the spindle? On my older machine the gear on the tail of the spindle is a 30 T.
And having a 70 T gear driven by a 21 on the g'box input shaft doesn't look right at all.
Any thoughts?
