At the risk of raining in anyone’s parade, no matter what machine you buy, the intial work that you get off it is unlikely to be as good as you had hoped.
You will need to become familiar with the machine, and acquire skill in using it.
Working to 1/6th scale means that the fits and tolerances that need to be applied will be smaller.
A two thou clearance on full scalle woiuld a loose fit at 1/6th, so you will need to become skilled at tool, grinding and honing, and how to set up the machine, to enable you to remove metal at MINUTE depths of cut.
Remember that as the size of the material that you are working decreases, so does the strength.
A 3mm rod is only 1/8 as stiff as a 3mm rod. Hence the need for tools that are REALY sharp and accurately mounted.
Maybe you will find that you need to set the gibs more tightly for your work, even if it makes the machine a little stiiffer to operate than most folk would normally prefer.
The comments about beginners over expecting what the machine and operator can produce in the early days is valid.
You didn’t get the best of economy, performance, or ease of parking out of your new car until you became familiar with it. The same will apply here.
As you become more familiar with the machine, your results will improve.
You will find the feeds and speeds that yield the best results for whatever material you are cutting.
This is all part of climbing the learning curve.
Practice makes perfect and nothing succeeds like suceess.
Just keep quietly working away
