One of the first thing that we were taught was how to use both hands, one taking over from the other, to provide a steady feed rate.
Like Mike Hurley, I prefer HSS.
As said, whatever the tool, the cutting edge must be on centre height. If all else fails, and you cannot make a Centre Height Gauge (Look in my Albums, if they are still accessible, to see the sort of thing ) You just set the edge of the tool so that it contacts the underside of the blade (Which has been set with the underside of the blade at centre height. )
For brass, I would suggest, on HSS, no top rake, and small front and side clearances.
On a carbide tip, unless the tool shank is held at an angle, these are preset for you.
How do you find centre height?
Take slow steady facing cuts across the end of a bar. When the tool has been set to Centre Height, there will be no "pip" in the middle, of the bar.
The cutting edge of the tool will be at centre height, so set your gauge to that so that it cannot move.
This will ensure that in future, any tools can be set to centre height.
If use a sharp tool set on centre height, the finish is determined by the rate at which you feed the tool in or along.
Too fast and you produce somethging like a screwthread. Slow and steady should produce a nice smooth finish
If you could measure your feed rate, you should be aiming for 0.002 – 0.004" (0.050 – 0.1 mm ) per rev.
Carbide tips usually have a small radius which improves the finish The radius is likely to be greater than the feed/rev, producing a series of overlapping radii, for a smooth finish.
As said, things need to be rigid. clamped firmly, with minimum tool overhang, and with gibs giving absoluterly minimal slop (just enough clearance to slide easily but with a slight drag )
A tangential turning tool, uses HSS toolbits make (two designs using 1/8" have been published in MEW )or buy, The latter means buying from Eccentric Engineering in Australia. This uses 1/4" HSS toolbits, and should come with a grinding jig.
They can be used for facing or turning, but have to be set to centre height using a gauge, (unless you are either very lucky at guessing, or have time to spare to experiment)
Most of my facing and turning is done using a tangential tool.
HTH
