Thank you Nick.
Looks as if this site is having IT problems too. This afternoon it was off completely by a server failure, it said. It’s still flakey now!
Oh Dear. I thought I’d asked a simple question – a small dimension-change. I had no idea it is so complicated, nor that my drawing was so bad. It took Jason and David quite some work to analyse and correct it. Now I’m seeing there are umpteen right ways to the same drawing, but I go and pick only the wrong ones; so I’m becoming ever more confused and disheartened.
You describe how you’d use projections but, sorry, you’ve lost me. That is an area of Alibre I know nothing about, but I did not have to project anything. I knew the seed hole’s location from centres that cannot be moved, and I knew the pitch-circles operate on those. I then Assembled the two covers alone, to verify the dimensions all match. I think in practice I’ll pilot-drill the covers on a rotary-table then spot through them to the block, rather than rely on co-ordinates I obviously cannot plot correctly.
I have to design a new cylinder block to match the original and other parts already made: I have to design and often re-design the entire project as I go along, often retrospectively; hoping that Part B just made does not need a new edition of Part A made twenty years ago….. (The chassis rails already have plenty of spare holes.)
All the main dimensions are fixed. They can not be changed; but I needed to draw cylinder covers to fit everything properly.
I could see no alternative to geometrical construction, in 2D; manually or as I used, TurboCAD’s direct orthogonal mode. This gave the dimensions to feed into Alibre so I did not need “juggle” anything there. It was my only feasible approach!
My mistake was simply forgetting a diameter already designed, and I made the block slightly too narrow. My original question was how to correct only that – I had no idea the whole drawing was complete rubbish.
I can’t draw my engine as you suggest, even with simplifying shapes of parts too hard in CAD. It’s an enclosed, inverted-vertical compound with Stephenson’s Link Motion (I’m cribbing the valve-gear from published designs). So two of everything. The side on dead-centre is slightly simpler but everything on the mid-stroke side is all at very odd angles. So I can’t see at all how to assemble all those parts in an Alibre 3D model, but I can’t draw the crankshaft and engine-case anyway.
So I could create a CAD G.A. for the engine only orthographically, in TurboCAD, whose extremely powerful 3D mode is impossible for me – but, the huge fly in the steam-oil is that printing a TurboCAD drawing is almost impossible too!
