Posted by SillyOldDuffer on 01/12/2020 10:54:22:
Welcome to the forum David.
Far from expert on 5" gauge railways but I'll have a go at answering the question in hope one of the experts will correct any mistakes!
- Ideally a railway line should have no gaps at all. Wear occurs at the rail ends because wheels drop into the gap with a thud with most of the force concentrated on the far edge. It damages the tyres and stresses the suspension too. The force increases with size of gap relative to wheel diameter, axle weight, and the speed of the train. Full-size railways today usually lay continuous track because it lasts much longer, reduces rolling stock maintenance, and doesn't annoy passengers with clickty-clack.
- The problem with continuous rail is heat expansion. Full size railways fit tapered sliding joints and/or stretch the rail on a cold day: on hot days the man-made stretch has to be overcome before heat expansion buckles the line.
- How much expansion occurs depends on the length of rail, and the temperature range it experiences throughout the year. What's a serious problem if the track runs a few thousand kilometres across the Australian desert is unlikely to be an issue on a short UK garden railway.
- In the same way, a gap unacceptable to regular heavily loaded full size freight trains at 60mph, wouldn't matter on a garden railway because it's lightly loaded.
There's an online calculator here. It suggests a 100metre length of Aluminium will expand by 66mm over a 30°C range. If the line is installed on a hot day midsummer with a small gap then the gaps will grow to a maximum in winter, when the railway is unlikely to be is use. What's riskier is laying the line in winter and calculating the gap based on predicted temperatures. Global warming appears to be responsible for what should be once per century extreme weather events: of the 19 top temperatures recorded in the UK, 8 have occurred this century. Highest shade temperature recorded ever recorded in the UK was 38.7°C in July 2019, compared with the average – about 17°C. Do you design for 17°C or 38.7°C?
Garden railway, I wouldn't overthink it. Be interesting to see what a club track layer says!
Edited By SillyOldDuffer on 01/12/2020 10:56:47
If the rails are in full sun they get quite a bit hotter than air temperature, we've measured 55C on a really hot windless day. If the gaps are too small the rails buckle, been there done that. If you're ever going to have track circuiting then spacers between the rail ends are a good idea, otherwise the gaps can close up over time
Edited By duncan webster on 01/12/2020 20:27:12
