Help 11NR14NPT insert
Home Forums Beginners questions Help 11NR14NPT insert
  • #470987
    woody1
      @woody1
      I wonder if any of you fine gentle can help or part with some of your wisdom. I need to thread an internal 1/2×14 NPS. However I cannot seem to source the titled insert in the UK. I am not sure if I am looking in the best places. This is my first foray into insert tooling.
      Thank you,
      Woody.
      woody1
        @woody1
        #470990
        Ex contributor
          @mgnbuk
          Cutwel appear to do these – see here.
          In stock at £18.84 each inc. Vat + delivery.
          Nigel B.
          #470991
          woody1
            @woody1
            I did see these but they are NPTF which I think is different but thanks.
            #470995
            Tony Pratt 1
              @tonypratt1
              Perceived wisdom is that NPS is a parallel thread & NPTF is a tapered thread but the form is the same?
              Tony
              #470996
              Ex contributor
                @mgnbuk
                Both 14 NTPF and 14 NTP are listed – use the Pitch/TPI tab at the top of the list to show all the available options.
                Part number of the 11 IR 14 NPT is 021-50346
                Nigel B.
                #470997
                  They list both types on the same page, try 7th one down, F is the fuel thread.
                  #470998
                  old mart
                    @oldmart
                    I don't know for sure, but I recon that 14 tpi would be more in the realm of 16 size inserts. The Cutwel site has the most comprehensive list of these inserts, or maybe APT. Your small starting bore will be the main problem, I would try looking for a tap which may be just as difficult.
                    #471004
                    woody1
                      @woody1
                      My bore will be around .749" so I don't think clearance will be an issue.
                      Thanks guys I didn't see the options, ordered.
                      #471009
                      old mart
                        @oldmart
                        I forgot that you have a pipe thread with a much bigger bore. Use a little pipe thread compound from Loctite and the slight difference in the thread won't matter.
