Hello – Help Needed with Bridgeport Wiring
Home Forums Introduce Yourself – New members start here! Hello – Help Needed with Bridgeport Wiring
  • #496363
    Scott Headington
      @scottheadington22530
      Hi Guys,
      Thank you for letting me join the forum as a new member. I have recently bought a Bridgeport Milling machine, J head, variable pulley model. On inspection the previous owner/ or owner before that had cut all the wires going to the control box by the knee. I have managed to trace wires back to the main control box via continuity testing. The fault I am having at the moment is when I turn on the machine then turn on the toggle switch ( far left) on the control box, the contactors come on, then when I press the green button the contactor disengages. I know this is wrong because it should be the reverse of what I just said. I have tried all different combinations with wires going to different places on the control box but I just seem to be coming up against a brick wall with this. Has anyone out there got a wiring diagram of the control box so I can get it up and running please??
      Scott Headington
        Bridge port Milling machine
        #496367
        Oldiron
          @oldiron
          Have you tried looking on Vintage Machinery.org They have a vast collection of manuals on most machines including Bridgeport. The manuals are all free to download although I think you can make a donation if you wish.
          regards
          #496369
          Bazyle
            @bazyle
            Nice to see you Scott,
            Perhaps this thread can be renamed "Bridgeport woring help needed" to get more attention from BP owners.
            #496382
            Chris Evans 6
              @chrisevans6
              I do have a manual for my Bridgeport. What year is your machine ? ( the serial number contains the date code)
              Lots of wiring changes over the years.
              #496741
              Scott Headington
                Hi Chris,
                The serial no on my Bridgeport is 358130481W.
                Does this tell you what model it is and year of manufacture?
                #496746
                Oldiron
                  @oldiron
                  You need the actual machine number from the knee casting then look up at at lathes.co.uk or globalmachinebrokers.com The number on the head will not work.
                  regards
                  #496755
                  noel shelley
                    @noelshelley55608
                    Welcome ! I have a wiring diagram that may be right, it is a poor copy. The control circuits seem to be from a 415v to 110v transformer. It sound as though the push button is n/c rather than n/o and operating it drops the contactors. send me a pm and I will try to help. Noel
                    #496831
                    David George 1
                      @davidgeorge1
                      Hi Scott I have a copy of the handbook in PDF format which has a wiring diagram at the end I will send a message with my email so you can send me an email with handbook attached.
                      David
                      #496846
                      Scott Headington
                        David, ok that would be great as I'm at my wits end with it. I just want to get it up and running. Cheers
                        #496888
                        David George 1
                          @davidgeorge1
                          Scott have a look at the top of this page there us a little mail symbol inbox just click it to receive messages when logged in.
                          David
