Hello from Yorkshire
  • #518064
    Steve Clowes
      @steveclowes16800
      Hi
      Recently retired and i've always wanted to finish a project of making a working model steam engine that i started with our teacher at school in metalwork. Now seems the right time. I served my apprenticeship as a tuner, back in the late '70's at Crabtree Vickers, but it's been many a moon since i used a lathe, so I've a bought a little ZELUS 7 x 14Inch Mini Lathe to start off with.
      First though, i think i need to get my eye back in and make a few basic things.
      Looking through some threads has given me some ideas ,so i'm looking at buying some material "stock". Anyway my laboured question is what sizes (round bar, flat bar, sheet), material (steel, brass, aluminium) etc would make a good store of stock for model engineering
      Sorry for such a long 1st post. I promise i won't bore you like this again
      Steve
      Steve Clowes
        @steveclowes16800
        #518100
        Brian Wood
          @brianwood45127
          Hello Steve,
          Welcome to the Forum. It is always difficult to chose material to build up a stock from and I would suggest you do so gradually.
          You will find M-Machine a useful organisation based in Darlington who supply all manner of materials and cut to size for postal delivery. If you buy a bit more than you need for a job in hand you will quickly build up a shelf full of useful oddments. Metals4U are another supplier, they are based in Wetherby for longer lengths and deliver from on line ordering
          I can recommend both
          Look at their websites http://www.m-machine-metals.co.uk
          http://www.metals4u.co.uk
          Regards Brian
          #518104
          Chris Evans 6
            @chrisevans6
            Welcome long Steve, the advice to buy a bit more than needed is sound for building up a stock. You also have some handy for when you produce scrap and have to start again.
            #518105
            John C
              @johnc47954
              Hi Steve,
              Where in Yorkshire are you?
              John Hinkley
                @johnhinkley26699
                Welcome, Steve,
                I'll second the above posts. M-Machine Metals are very good – fast delivery by courier in my experience and you are getting proper grade materials, not always the case if you order off eBay etc. Having said that, I've had satisfactory dealings with eBay traders called "steelcitygav" and "peninemetals".
                I'm based near Doncaster, though born in Kent and thus a relative newcomer to Yorkshire.
                Tony Wright 1
                  @tonywright1
                  What size materials should I buy ? Are you having a laugh ? Hm let’s think oh no I can’t work that one out for my self!
                  #518120
                  Howard Lewis
                    @howardlewis46836
                    Welcome! Plenty of help always available on here, on a wide variety of subjects.
                    There are a number of suppliers to the Model Engineering fraternity. College Engineering Supply, Noggin End metals, MACC come to mind, but there are others.
                    Try looking on Google for Model Engineering suppliers..
                    Plus, you can obtain some supplies from a local stockholder. The only disadvantage here, is that you may need to buy a 3 metre length, and possibly pay to have it cut into shorter lengths.
                    Buying just a short length can be expensive, in my experience.
                    HTH
                    #518123
                    Brian H
                      @brianh50089
                      Hello Steve and welcome but ignore some of the comments. My advice would be to decide on a project to build and then order just the sizes needed but with a bit of extra length for holding or to put into stock. This will give you enough to remake anything that goes pear shaped or to provide a scrap bin of useful bits.
                      For workshop projects I can recommend the books by Harold Hall or, if you fancy a steam engine then the sets by Stuarts are good but not cheap.
                      I'm sure that it won't take you too long to get back into turning and I wish you all the best with that.
                      Any questions will generally provide useful answers on here and remember, there are no stupid questions but there are, occasionally, stupid answers.
                      #518127
                        Posted by Steve Clowes on 06/01/2021 22:20:04:
                        Steve
                        No need to apologise, it's a good question.
                        Based on my experience and reading what others have said about setting up a workshop, I've decided the best approach is personal. It depends on you Steve!
                        One way is to strive for perfection from the get go. Purpose built workshop with carefully planned benches and storage plus lathe, mill, pillar drill, compressor, cutters, measuring gear, and a large stock of metal, wood and plastics in all possible sizes. Wonderful!
                        Not how I approach the hobby. Unsure of what exactly I was going to make (I'm not a modeller or restorer), I buy tools and materials piecemeal as needed for each project. I did decide I was metric rather than imperial, but apart from that kept an open mind. Hand-tools and a pillar drill soon proved inadequate, and I realised I needed a small lathe, then a big lathe, a milling machine and – most important – a band-saw. (Because cutting metal by hand is a boring, tiresome timewaster!)
                        First mistake was trying to learn on scrap metal. Very disappointing results, which turned out to be because my scrap collection was all unsuitable, and DIY store metal ain't much better. Soft squishy Aluminium Alloys, work-hardening stainless steel and other obnoxious stuff. I was unlucky because all of it was unfit for purpose. Much better to buy known metal where the description says it's suitable for machining.
                        To make a start and get a feel for the lathe whilst keeping costs down I'd buy a metre each of 10mm-ish diameter Brass, Ordinary Steel 'EN3', Machineable mild-steel 'EN1a' or 'EN1aPb', and a machinable Aluminium alloy.
                        Having tirned, threaded, faced, tapered and bored the above, make something! I found Stewart Hart's Potty Mill engine to be an excellent beginner challenge, being hard enough to develop new skills and make me think, but not so difficult as to reduce me to tears. No castings, everything is fabricated from stock size metal. The maker has to shape different materials, in some places accurately, and then assemble and debug the engine so it runs. It taught me a lot.
                        Building the engine involved studying the plan and identifying the metals and sizes needed to make it, A mild-steel base-plate cut from rolled-strip; brass pillars, steel runners, aluminium cylinder, brass piston and bearings, silver steel axle. So having found the cylinder was made of 35mm diameter aluminium rod, I ordered a metre, used about 50mm to make the engine and kept the rest as stock. Four years later, I'm down to my last 150mm and need to buy more. Same with the other sizes; identify what's needed, and over buy moderately to build stock.
                        Turns out I use a relatively small number of stock sizes and shapes. More rod than strip, and more strip than heavy section. Not much Hex or angle. I'm more likely to turn 10mm and bigger diameters than below, I use more Aluminium than steel, but Brass is popular too. It would have been a mistake for me to order a lorry load of expensive metal because I don't use most sizes.
                        But that's just me: other workshops operate differently – it depends on what you make, how much you specialise, and how much not having metal and tools to hand annoys you. Clockmakers major in small Brass, motorbike fixers go more for mid-sized steel and aluminium. I have a local metal Emporium and can get metal in an hour or two, so running out isn't a crisis. I'd hold more stock if I had to order everything online and wait for it to be delivered.
                        Steve Clowes
                          @steveclowes16800
                          Posted by John C on 07/01/2021 09:27:12:
                          Hi Steve,
                          Based in Leeds
                          #518146
                          Steve Clowes
                            @steveclowes16800
                            Many thanks for the replies. Lots of good ideas which i will take on board
                            #518152
                            Brian H
                              @brianh50089
                              SoBs answer is spot on. Make sure that you buy material of known specification such as EN1A for mild steel. although that designation is well out of date almost all metal suppliers will know what you want and EN1A is a lot easier to remember than BS 970 230M07.
                              #518177
                              Steviegtr
                                @steviegtr
                                Hi Steve & welcome from another Loiner. Back in the 70's quite a few of my mates were apprentices at Crabtree's. Was it Water Lane. just before the old Startrite bike spares.
                                Steve.
                                #518178
                                Harry Wilkes
                                  @harrywilkes58467
                                  Welcome to the forum
                                  H
                                  #518218
                                  Steve Clowes
                                    @steveclowes16800
                                    Posted by Steviegtr on 07/01/2021 16:02:50:
                                    Steve.
                                    Yeah, there for as year 1977 and then onto South Accommodation Road
                                    #518606
                                    Iain Downs
                                      @iaindowns78295
                                      Metals4U based in Weatherby will sell in small lengths and have a good range of metals. They will deliver (for a cost), but you can drop in and collect (Covid rules permitting) as well.
                                      The option I mainly use these days is eBay. There are a lot of metal suppliers whose prices (even after postage) are quite keen and it's quite convenient.
                                      I'm in Harrogate, so just round the corner.
                                      Iain
                                      #519419
                                      drum maker
                                        @drummaker82202
                                        another from the yorkshire clan… welcome, welcomelaugh
                                        #519437
                                        alan ord 2
                                          @alanord2
                                          Durham born and bred but now living in Doncaster. Welcome to the forum. Agree with what has already been said. I buy material for a job but always order more than needed (in most cases 1 metre lengths). The balance goes into store. You will soon build up your stocks.
                                          Alan.
                                          #519441
                                          Ian Childs
                                            @ianchilds37813
                                            Blackgates, just down the road from you in Dewsbury. Otherwise Maccmodels, (in Macclesfield) always had excellent service from both. Macc is more mail order orientated than Blackgates.
                                            Edited By Ian Childs on 12/01/2021 21:35:43
                                            #519524
                                            Tony Wright 1
                                              @tonywright1
                                              Hello Steve, any relation to the Clowes family from Hull ? Just wondered known a Tony Clowes for the last forty years.
                                              #519572
                                              Steve Clowes
                                                @steveclowes16800
                                                Posted by Tony Wright 1 on 13/01/2021 11:02:03:
                                                Not that i know of, all from around the Leeds area since the 1900's
