Hello from the Netherlands
Home Forums Introduce Yourself – New members start here! Hello from the Netherlands
  • #434470
    Jurrian Mulder
      @jurrianmulder17808
      good evening,
      I am Jurrian Mulder, an engineering student from Holland. I work a lot with machining and Cad for my study, but in my free time I like to tune 2 stroke engines. I have my own bridgeport milling machine, and a hobby lathe. just bought a second lathe, an Italian one. I don't know the brand yet, hoping you guys could help.
      greetings,
      Jurrian Mulder
        @jurrianmulder17808
        #434505
        Kevin Murrell
          @kevinmurrell62078
          Greetngs!
          Send us a picture of the new Italian lathe – almost certainly it can be identified.
          K.
          #434506
          Chris Evans 6
            @chrisevans6
            Welcome along Jurrian from another |Bridgeport user.
            #434515
              Welcome to the forum, Jurrian.
              Jurrian Mulder
                @jurrianmulder17808
                Hello,
                thank you for the reactions, here some pictures of the lathe. There's no type plate, only some text about the type of oil and about a lock. Hope the images work
                https://ibb.co/TH8yGX1
                https://ibb.co/0mMK0RV
                https://ibb.co/TWMxHb9d
                Edited By Jurrian Mulder on 27/10/2019 10:51:26
                Edited By Jurrian Mulder on 27/10/2019 10:54:29
                #434880
                Emgee
                  @emgee
                  Hi Jurrian, welcome to the forum. That's a sturdy heavily built machine, useful for very many jobs.
                  (BTW the bottom picture link didn't work for me)
                  Emgee
                  #434881
                  Emgee
                    @emgee
                    Sorry, double post but can't seem to be able to delete it, needs a moderator's touch.
                    Edited By Emgee on 27/10/2019 11:51:58
                    #434890
                    Jurrian Mulder
                      @jurrianmulder17808
                      Judt found out how to post pictures directly, so here they are.
                      Some more information about the lathe:
                      So as i said there is no type plate or anyting on the in or outside of the machine. It has a bison 160mm chuck on there, which I think isn't original. The lathe has autofeed in both directions, with 6 different feeding speeds. There is a 2 step 3 phase motor in there, 700 and 1400 rpm. 4 different sizes pully at the motor and 4 at the main shaft. Rpm range is 250rpm until 3100 rpm. It has a clutch and brake in the drivetrain, and a lock to lock the main shaft in 6 positions, each 60 degree. Oilpump is there aslo, but not working at the moment. All text is italian. I have looked the list at lathes.co.uk, but couldn't find anything.
                      Edited By Jurrian Mulder on 27/10/2019 13:33:27
                      #434909
                      old mart
                        @oldmart
                        Welcome, Jurrian, your lathe looks good, maybe a toolmakers lathe, it is very heavily built for its size.
                        #435986
                        noel shelley
                          @noelshelley55608
                          Hi Jurrian, welcome to the club. Where abouts in the Netherlands are based ?
                          Best wishes Noel.
                          #435990
                          Brian H
                            @brianh50089
                            Hallo Jurrian and welcome to this helpful forum.
