Hello from the Cotswolds
Home Forums Introduce Yourself – New members start here! Hello from the Cotswolds
  • #40594
    Diogenes
      @diogenes
      Diogenes
        @diogenes
        Hello.
        Although very new at posting, I have a little experience with machine tools and workshop practise. I've been a reader of MEW for a number of years, and am not totally unfamiliar with this forum.
        After spending far too much of my life either doing itinerant site-based work or living in unsuitable accommodation, I have at last managed (more-or-less) to manoeuvre myself into both more local work and a place with a reasonable-sized workshop which I am in the process of setting up.
        I have a few pieces of tired-but-useable machinery up and running, and a couple of small projects on the go.
        Having got this far with the necessary adjustments to my life, I hope my reward will be the ability to spend a bit more time in the workshop.
        Kind regards
        D
        #423856
        Daniel
          @daniel
          Hello Diogenes,
          Welcome to the forum.
          Happy workshop times ahead. You"ll find a wealth of information amongst a friendly group here.
          ATB,
          Daniel
          #423861
          Brian H
            @brianh50089
            Hello Diogenes and welcome to the forum. What are the intended uses for your workshop and machinery?
            #423897
            Mohammed Arsath
              @mohammedarsath64877
              Hello Diogenes, Welcome to our community.
              #424103
              Diogenes
                @diogenes
                Hi, thanks for your kind responses – apologies for my late reply, I'm currently in process of completing the actual move itself..
                I guess that the two projects currently underway illustrate the kind of things that I enjoy doing – I'm cobbling together a Heath Robinson tool grinder from the scrapbox, mainly in order to achieve greater accuracy in such items as threading tools, and reduce the tedious cycle of "offer-up & adjust slightly"..
                Whilst I'm happy grinding most tools off-hand, it IS something that I find has to be done regularly to achieve any sort of efficiency – once it's almost habitual, it's a breeze, but when one has to contemplate the moves, it's a bore.
                The other project is a little Cyldon that was handed to me as a boot-sale find. The boiler was intact, as was the pipework, cylinder support bracket/port block, burner, and whistle. Rather than a thorough restoration, I've had a surprising amount of enjoyment carrying out a fairly pragmatic repair, making a fabricated flywheel, replacement cylinder and piston, and a safety valve on my little Hobbymat. I'll try and upload some pictures.
                I find that I've reached that point in my life when small steam engines are starting to exert something of a pull.. I will have to build one from scratch.
                Other than that, and perhaps in common with many other members here, I carry out the usual range of domestic repairs & replacements, and the occasional bit of free ("I don't suppose you could make me a…&quot motor engineering for friends and family.
                #424104
                Diogenes
                  @diogenes
                  There must be something wrong with the facial recognition system – I was actually rolling my eyes, when I wrote that, not winking.
