Hello from Brisbane, Australia
Home Forums Introduce Yourself – New members start here! Hello from Brisbane, Australia
  • #566181
    Rodney Nissen
      @rodneynissen27512
      I'm a wannabee model engineer, ever since I read Neville Shute's "Trustee from the Toolroom" in school.!!! I went to sea as a Marine Engineer initially in Australia and then in the UK.
      I have a good workshop (albeit very untidy) set up with lathe and vertical mill, but so far only used it on occasion for work stuff as I have my own business working in the industrial combustion field.
      All the best,
      Rodney
      Rodney Nissen
        @rodneynissen27512
        #566182
        Brian H
          @brianh50089
          Hi Rodney and welcome to the forum. I don't think the forum allows people in if they have a tidy workshop!
          So, what sort of model engineering are you interested in? perhaps a marine triple expansion engine?
          #566186
          Rodney Nissen
            @rodneynissen27512
            Hello Brian….my middle name too!!
            Ah ……yes steam
            LORD, Thou hast made this world below the shadow of a dream,
            An taught by time, I tak it so……exceptin always STEAM…….
            Cant beat Rudyard. He had a poem for anything worth it.
            When I went to sea, I was on steam turbines, but we had to answer questions at the DOT/ BOT exams on steam reciprocating. Later on I was on motorships (diesels) and lots of Doxford opposed piston engines. However they had the steam operated Weirs feed pump on the auxy boilers. I became an expert on these. I would love to make a model of one of these. I contacted Weirs in Scotland years ago and they said they would send me drawings, Alas they never arrived.
            I did buy a book on miniature internal combustion engines but thats maybe running before I can walk.
            All the best
            #566190
            Brian H
              @brianh50089
              Hello Rodney, you may be interested in this;
              https://modelengineeringwebsite.com/Weir_pump.html
              All the best,
              #566269
              Rodney Nissen
                @rodneynissen27512
                Thanks for that Brian.
                I'll try contacting Weirs again for a drawing. They closed their Cathcart works in 2006, but there is still a Weirs Group around.
                Re the pump. When joining a ship, you could tell how well the pump had been maintained by the appearance of hammer marks on the valve chest end covers. The steam shuttle valve inside when set up and adjusted properly used to oscillate back and forth smoothly without hitting the end covers or sticking. Hammer marks were a telltale that the valve was sticking.
                #566337
                John Olsen
                  @johnolsen79199
                  Most of the Weir pumps had Monel metal piston rods. I have about four inches cut from one that had been quite badly seized. I also have a copy of their catalogue somewhere, I wonder where that is?
                  Rodney Nissen
                    @rodneynissen27512
                    I have a manual for an old horizontal Worthington pump "somewhere too". When I find it, will scan it and then the electronic copy will be available forever!!!
                    #566339
                    Paul Lousick
                      @paullousick59116
                      Hello Rodney (from Paul in Sydney) Welcome to the forum.
                      I believe that Blackgates Engineering, UK may sell castings for model Weir pumps as shown in this video.
                      Rodney Nissen
                        @rodneynissen27512
                        Looks good Paul. Thanks for that.
                        Rodney
                        #566365
                        Paul Lousick
                          @paullousick59116
                          If you decide to make one, keep us updated. I have already made some small steam engines and a 6" traction engine and a Weir type pump is in the bucket list.
                          Cheers, Paul
                          #566389
                          Rodney Nissen
                            @rodneynissen27512
                            How do you run your engines Paul? Have you a boiler or steam supply? Or compressed air?
