Hello Everyone a keen beginner
Home Forums Introduce Yourself – New members start here! Hello Everyone a keen beginner
  • #40108
    Robert Steele
      @robertsteele45633
      Robert Steele
        @robertsteele45633
        Hi everyone, I suppose this is the place to start? I find myself here to seek help and advice to stop me from making some costly mistakes. I work as a locksmith hence the tools I use in my trade are individually specialised and very expensive indeed. I have some variations of my own that i would like to try out, these small tools will be from stainless/brass maximum size roughly 40mm x 170mm rod, fine tolerance is important. would anyone advise. What would be a suitable small lathe for me to start having a go at my own ideas. Thanks.
        #300611
        Brian H
          @brianh50089
          Hello Robert and welcome to this forum.
          The choice of lathe is a very personal one and also depends on what is available and how much you want to spend.
          A good second hand one is a possibility but many people seem to do well on the smaller foreign lathes. It would be good if you can get to one of model engineering exhibitions such as the Midlands Model Engineering Exhibition at Leamington Spa on Thursday 19th October to Sunday 22nd October 2017.
          #300674
          Bazyle
            @bazyle
            40mm is not going to fit in the spindle of a typical Model engineering / amateur / home lathe but you can still work on it using a fixed steady. You probably don't want too big a lathe for space and cost reasons if you aren't using it a lot but since stainless is a bit tough you want some strength and rigidity so don't go too small and weak. I suggest one with a 9 inch swing (4 1/2 centre height) and remember you will want a fixed steady and both 3 and 4 jaw chucks. The new far eastern ones come with these items normally but second hand (eg Boxford) may not and can add significantly to the cost. You might want to consider whether the shapes of things you want to make would dictate a milling machine as a better starting point.
            #300706
              Hello Robert,
              Welcome to the forum.
              This sounds interesting stuff!
              Howard Lewis
                @howardlewis46836
                Welcome!
                Where abouts are you based?
                Even with a lathe with 5MT spindle, you are unlikely to pass anything larger than 38mm through the mandrel.
                As already suggested, grip the work in the chuck, and use a steady, but ideally you would need to pass the work into the mandrel to turn a bearing diamater that is concentric. At 40mm , unless you have a pretty large machine by Model Engineering standards, that is not possible. I would suggest, using the steady and centre drilling each end so that the work can be turned between centres.. But the stock ought to be a bit bigger than 40mm, so that it can be turned down to minimise run out, and keep it concentric with the centreline of the machine.
                If you hold a short piece of material in the chuck, and turn it down to the diameter of the workpiece that you want to turn, you can then set the steady to this turned diameter, for use on the actual material.
                Howard.
                #300850
                Robert Steele
                  @robertsteele45633
                  Thanks very much for your input chaps, All sounds like very valuable advice and most of it I understand. Im learning this terminology as I'm going along? I'm based in North Wales, yes space is tight so that will need to be a consideration. I wonder If I could post a small photo with an example of the tool parts i would like to manufacture, obviously without any parts that may compromise anyones security. Also if in the meantime if anyone knows of any used equipment that may suit my needs please let me know.
                  Thanks once again.
                  Rob
                  #300889
                  Howard Lewis
                    @howardlewis46836
                    Your choice of lathe will depend on a number of factors. Space, Budget, work to be undertaken, availability of accessories such as chucks, steadies etc.
                    Since you have mentioned working on 40mm diameter material, you are likely to need a fairly big lathe, by most model engineering standards.
                    A Mandrel with a 5MT taper, may not accept anything larger than 38mm, based on the Chester Craftsman (which is cousin of the Warco BH600 and the ETR BL 12-24) The later geared head successors will be likely to have 5MT Mandrels.
                    You could buy a used machine, but : ex Industry they will be well used, or ex Tech College/School may be little used but carry battle scars. ; and may be fitted with three phase motors. No problem if you have a three phase supply available, but could mean extra expense / complication if you need to convert (Invertor or different motor) to run off a single phase supply. Availability of accessories may be a problem with second hand machines.
                    If you do go for a secondhand machine, try to take someone knowledgeable with you to examine / test it thoroughly. A mistake, such as a worn bed, could prove expensive.
                    And bear in mind the cost of moving it to your workshop, and any likely access problems. (Moving 300Kg of machine down a step and around a corner at the same time, and then lifting it up 8 or 10 inches into the shop and then into position on the bench could be difficult – I know)!
                    And when you install your machine, make sure that the shop is well insulated and well ventilated, to prevent rust problems. With regard to machine installation, my hobby horse is to ensure that the bed is not twisted. The tailstock can be adjusted to the centreline, but a twisted bed will result in unwanted taper turning.
