Hello all – new member here located in Milton Keynes and looking for some advice please.
I have recently purchased a Bridgeport Series 1 J Head mill and am currently getting familiar with the machine.
There are You-Tube videos that I have found helpful for things like gib adjustment and backlash adjustment however I cannot find anything on one issue I have spotted related to the the knee travel
The issue is as follows:
The knee runs upwards normally when the handle is turned clockwise. On occasion – not every time – when turned anti-clockwise there is approx 360 degrees of rotation where no resistance can be felt on the handle and the knee does not lower. After about a turn some resistance can be felt on the handle and the knee will then drop a visible distance with a dull thud. From this point on if I keep turning anti-clockwise the knee lowers normally.
I have carried out the following in an attempt to understand what is going on and eradicate the issue;
1 – raised and lowered the knee to full extents top and bottom and cleaned and oiled the slide-ways.
2 – Attempted an adjustment to the vertical gib but was unable to do so. I removed the gib cover and felt wipers and tried turning the gib adjusting screw but it is solid. It moves neither clockwise or anticlockwise despite applying good purchase with the blade of the screw driver.
After carrying out No 1 above the issue seemed to go away temporarily. However 20 minutes into a small job it re-appeared. Like I say – it is not there all the time.
I hope I have given sufficient description for people to chip in.
Any ideas as to the root cause and how I might pin-point and rectify the issue? All advice would be very much appreciated.
