hello thanks for the add into this world of engineering. I am a wheel builder and frame builder for motorcycles, and as machinery for this type of engineering is so limited I have to make a lot of the machinery and convert what is out there to suit my requirements
I have a problem and wonder if any members may have made a small machine or know of one to do the job.
I have a Waterbury Farrell thread rolling machine using flat dies, I have recently tried to roll m4 x 7 threads onto 9 swg spoke stock, it produces a good thread alas it is reading 3.95 od, standard m4.7 threads read 3.80 od, although the thread is snug in the nipple, I am using 7070 aluminium for the nipples and using cut thread die both in a drill tap and or a drill and tap, these nipples are machined in a cnc machine as the opposing thread on the nipple is m4 ,7 LH thread. the rod stock is not available in the metric size, and I was looking for an idea to cut the spoke to size then reduce the proposed threaded end to the prescribed size required ready for rolling, the reduction process can be either ground or rolled, an engineer said today that if I turn the die blocks around it may reduce the rolling area to what I need, this I can see a problem as there would be no grip to roll the spoke stock between the die heads, increasing pressure of the die rolling heads to try a deeper cut and reduce the size that way will lead to the spoke stock squashing in the die, if it does that it jams up the machine and 15 mins is spent stripping and resetting the machine back to working order, the spoke length to be used is 100mm and 35 mm, and the reduction has to be done in seconds…. any ideas or has anyone seen a machine out there that may do the job, also I am looking for a heading tool to put spoke heads onto spoke stock, its a bit like forming a small nail head onto the end.
