hello
hello
  • #637554
    thomas gibson
      @thomasgibson83263
      hi just to introduce myself to the fourm i am interested in purchasing a lathe to learn the trade as i am a mechanic by trade and want to repair more parts
      thomas gibson
        @thomasgibson83263
        #637611
        Mike Hurley
          @mikehurley60381
          Welcome to the forum Thomas, plenty of friendly useful info on here.
          Unfortunately your comment ' I am interested in purchasing a lathe' is one that appears here regularly and there is no simple answer as it depends on a hundred and one factors – such as £ available, space available, your skills, size and type of 'parts' you which to repair etc etc.
          Suggest you go to the home page and half way down there is a search box – put in 'basic lathe type' or 'beginner lathe suggestions' etc or something similar, and you will find masses of info and previous answers to questions similar to this.
          All the best, Mike
          #637625
          Chris Evans 6
            @chrisevans6
            Welcome along Thomas. My motorcycle tinkering requires a slightly bigger lathe and mill than the average model maker needs. My advice is don't rush into buying anything until you gain a bit of an idea on the size of parts you may work on. Where are you based ? if someone is fairly local you may be able to arrange a visit to look at machinery.
            #637672
            Howard Lewis
              @howardlewis46836
              Welcome!
              What lathe you buy will depend on what you want to do with it.
              A watchmaking lathe will be no good for making replacement 7/8 BSF wheel studs for a commercial vehicle.
              Nor will a lathe capable of swinging 12" be ideal for making 10 BA screws or nuts
              The nice to have features, such Power Cross Feed or Norton gearboxes, tend to be incorporated inn the larger machines.
              If in doubt, buy one msize largerbthan you think, for mwhem your horizons and mambitions expand, having found just how useful a lathe can be.
              You can do small work in a big lathe but much more difficult ithe other way round!
              The purchase doesn't stop with the machine. You will need cutting tools, measuring equuipment, probably Taps and Dies, and when you feel the need for a 4 jaw chuck, you will need at lkeast one DTI and a magnetic base.
              You don't have to buy everything at once, but as you need it, or the finance becomes mavailable.
              If you decide to buy secondhand, try to find someone knowledgeable to come with you to see and check the machine. Try to find a local model engineering club, and join.
              Don't be taken in by a shiny paint job on a 60 year old machine, a slighty dirty mmachine in "original" condition might be a better buy..
              Often, a lot of kit will come with a mused machine, such as when clearing a deceased relative's workshop.
              That could be a good chance for you to become well equipped.
              Once you have the basics, you can gain experience and confidence by making simple tooling, and save money.
              It may be that the accessory you make will be specific to that machine, ,or, purpose, (Dollies for removing or fitting bearings,, for instancve )
              Enjoy yourself!
              Howardf
              #637676
              noel shelley
                @noelshelley55608
                Welcome Thomas, others have covered your point well. Where abouts are you? Noel.
