Helicoiling before Alocrom finish
Home Forums Workshop Techniques Helicoiling before Alocrom finish
  • #147679
    James Staniford
      @jamesstaniford
      Hi Guys,
      Can you insert stainless steel helicoils into aluminium before an alocrom treatment?
      Thanks in advance
      James Staniford
        @jamesstaniford
        #147680
        Ian P
          @ianp
          I suspect not but the people doing the anodising or whatever would know.
          Ian P
          #147686
          Bubble
            @bubble
            Hi Jqmes
            Alocrom is unaffected by steel, brass or copper inserts in the articles being processed
            extract from anochrome.com/ alocrom website
            Jim
            #147687
            James Staniford
              @jamesstaniford
              Thanks Jim, that's great
              #147689
              Clive Hartland
                @clivehartland94829
                I suggest you thoroughly flush any threaded or insert holes after Alochrom treatment, I have found that salts do stay in the holes. I find on new parts for the instruments are often not cleansed of residues. Even finding small bits of metal when the holes are blown out. The problem is that these salts can make the fixing screws lock up and snap off on dismantling.
                #147737
                Bill Pudney
                  @billpudney37759
                  When I had to work for a living I vaguely remember putting the following note, or something like it on drawings of aluminium bits.
                  "Alodine/Alochrom prior to inserting thread inserts".
                  The reason was that whilst the insert was ok with the treatment, the tiny gaps between insert and parent metal could and would retain small quantities of the stuff. Similar to Clives comment above.
                  cheers
                  Bill
