Home › Forums › I/C Engines › Heat Treatment of I/C Cylinders
Edited By Jens Eirik Skogstad on 14/02/2010 19:32:57
Edited By Jens Eirik Skogstad on 14/02/2010 19:38:58
Hello Ramon, a slightly different type of 2-stroke piston engine my flash steamer revs to 15000 with no load 10,000 under load.
I use an unhardened cylinder liner of en24t and use a cast iron dykes ring on a cast iron piston.
Edited By meyrick griffith-jones on 14/02/2010 22:31:28
Edited By Ramon Wilson on 15/02/2010 00:10:05
Edited By Ramon Wilson on 15/02/2010 00:12:27
Hi, just a few thoughts I might pass on. First why not use a chrome/moly cylinder and a cast iron piston, unhardened, apparentley the expansion rate is minimal, so the piston should not jam up,also wear is acceptable, anything over 5cc you could use an aluminium piston and make your own cast iron rings, (modelenginenews has lots of articles and info on this subject), in all cases the piston fit is very important, so lapping carefuly is a must.
See Dave Fenner’s articles on building the Sugden special in last years MEW and the problems he had with piston fitting and lapping, Geometer and modelenginenews, has lots of info on this subject.
I am in middle of making the Boll-aero 18, useing crome/moly cylinder and cast iron piston, The chrome 22mm rod I got out of scrap bin at the metal suppliers and the cast iron????? I will cut off an old V8 oil pump. If the oil pump is cast iron thats good !!!!! (I will still use it even if it’s not) because some of the holes through the pump are up to 100mm long with diameters varying from 1/2″ to 5/8″, these were ground for a good fit of the shafts,(make good cylinders), Jens said he uses front wheel drive shafts, a cheaper alternative is rear half shafts, especially trucks, these are some times much thicker, E.Westbury and L.E. Sparey used these for making collets, but they were heat treated before and after, I think with modern cutting tools, machening these as is, should not be a problem.
Its been 3 months since I finished the crankcase out of Al and main shaft out of a high tensile bolt (old engine) and nearly completed the cylinder, but it got hot down here, up to 40 degrees C in the shade, but much hotter inside the 2 car garage, so I have been insulating the walls and roof of my large metal built workshop, I am about to start finishing this engine, let you know how ends up. Sorry for rabbiting on, I hope this topic is a help.
John Holloway.
Edited By Jens Eirik Skogstad on 15/02/2010 20:19:57
Edited By Ramon Wilson on 15/02/2010 22:15:43
Edited By meyrick griffith-jones on 16/02/2010 22:12:33
Edited By meyrick griffith-jones on 16/02/2010 22:17:09
Edited By Ramon Wilson on 16/02/2010 23:59:36
Les
Les, Hi, go to the modelenginenews site, note, there is no spacing between the words. There is a full description of all the ED engines, that is quite detailed, on construction , history, and re-assembly, Iv’e just had a quick look, not the indepth articles even so its comprehensive.
Ramon, Hi, its a bit cooler after the record rains we have had in the SE of OZ. Now that Iv’e cleaned most of the junk and rubbish out I can start making swarf.
Anyway I seem to have read articles by E Westbury and others on the use of various metal combinations, for IC engines, I also think MEN has similar articles, This site, especial if you are a member is absolutley massive, you can read for a week solid and still see everthing that is written and photographed.
The article on making contra pistons, that fit and work straight of the lathe is an eyeopener, I think that it also refers to cast iron and steel as a contra piston and what the ramifications are.
PS I dont have problems on timeing/logging out (yet !!!!!). thats brobably because I use OPERA as a browser and mail recipient, its also the fastest browser around, I can read, write, make coffey, read links, check spelling and go back to Windows explorer to do other checks. Maybe Im’e just lucky so far.
John Holloway.
Edited By meyrick griffith-jones on 17/02/2010 18:46:09
Edited By meyrick griffith-jones on 17/02/2010 20:27:53
Home › Forums › I/C Engines › Topics
Started by: nevillet
in: Workshop Tools and Tooling
Started by: Duff Machinist
in: General Questions
Duff Machinist
Started by: Dalboy
in: Books
Huub
Started by: David Deaville
Denis O’Kane
Started by: Bill Phinn
in: Workshop Techniques
Started by: dangermouse
in: Manual machine tools
Paul Kemp
Started by: Robert Graham
in: Electronics in the Workshop
peak4
Started by: t1krt
t1krt
Started by: ell81
in: Beginners questions
Robert Atkinson 2
Started by: Steve Withnell
in: Work In Progress and completed items
Mike Hurley
Started by: brucemc777
brucemc777
Started by: Phil Whitley
in: The Tea Room
Phil Whitley
Started by: Harry Wilkes
Harry Wilkes
in: Drawing Errors and Corrections
Steve Withnell
Started by: ferroequinologist
ferroequinologist
Started by: JasonB
in: The Tea Room
Nigel Graham 2
Started by: Sonic Escape
Nicholas Farr
Started by: t1krt
in: Introduce Yourself – New members start here!
t1krt
Started by: Keith Matheson
Howard Lewis
Started by: ell81
Howard Lewis
Started by: jacques maurel
Andrew Tinsley
Started by: Dr_GMJN
in: Books
Pete
Started by: ryan.carter848
in: Books
Pete
Started by: keel
duncan webster 1
