To do the best heat treat you really need to be sure of the metal.
Ground flat stock is most commonly 01 and is a good blade material. You can't do better than follow the suppliers instructions for temperatures. You can, however, refine the grain, which is not often in the instructions and can significantly improve toughness.
If you can't find instructions, try this:
Heat to 870C and and cool in still air
Heat to 830C and cool in blown air.
Heat to 800C and cool in blown air.
Heat to 800C and quench in oil – any oil, veg oil, engine oil.
If you have tight temperature control at those high heats then you can soak for a while quite safely. I don't think you need to for a blade, but 5 or 10 mins should do it. The first heat is more important to soak than the last.
If you don't have good temp control, then don't soak at high temp for long – just get it to temp.
Temper at 220C for one hour – a bit longer if a really thick blade. Some O1 guides suggest a toughness peak at this temp – going a little higher can reduce toughness.
Heat treat may result in breakage.
8" long, 1/2" thick is outside my experience and longer soak times at high temp, and higher temper may be more appropriate – find the instructions!
If the 'tool steel' is not O1 then it may be air hardening and oil quench could be too risky. If in doubt, and you want to be safe, first 'quench' in air and see if a file skates on the surface… if not then quench in oil. Repeating heat treat is OK, quenching too slowly does no harm – it just doesn't get hard. Quenching too fast will result in breakage.
Edited By jaCK Hobson on 31/05/2016 08:35:44
Edited By jaCK Hobson on 31/05/2016 08:39:13
Edited By jaCK Hobson on 31/05/2016 08:43:36
