Posted by Brian Oldford on 07/06/2015 09:08:17:
Posted by frank brown on 07/06/2015 08:47:37:
For self amalg tape, when applying stretch it so it goes to a half of its original width. Lot easier to say then to do!
Frank
By all means stretch it slightly as you apply it but I'd not recommend stretching it that far. It sounds like any advice you received to use it that way was trying to avoid the use of the PVC tape over-wrap to apply pressure.
I'm not sure why there would be any restriction to how much self amalgamating tape should be stretched. The only limit I know of regarding stretching is its breaking point!
My understanding is that it is designed and made for stretching, actually I can't imagine how it could be used unstretched.
It is a product I have used for quite a few years and its the stretching that make the layers adhere to each other. I have used it to make cable replacement strain grommets for things like power tools. Its easy to create thick section where the cable clamp grips and then a long gradual taper that might only be a few though thick at the end.
Ian P
