As stated, heat treating PLA (referred to colloquially as 'annealing'
will both:
- significantly strengthen the PLA part
- make it temperature stable up to about 120c (ie as good as ABS)
But it needs to be done relatively carefully to avoid warping or distorting the part. I use one of the small consumer bench top ovens that I removed the top element from. I also recalibrated the temp control using a temperature probe on the middle shelf (ie where the item to be heat treated is placed) to have a more accurate indication of actual part temperature.
The best results I found are obtained by bringing the part up to to 60c, 80c, then 100c in one hour for each stage, and then back down in one hour stages. There can be very slight shrinkage on X and Y axis that may affect larger parts.
I would like to be able to rig up some sort of programmed PID control to do avoid having to do the settings manually but haven't been able to figure it out!
If you go down the same route, try to get a circulating oven if they make them – the internal temperature will be much more even.
