Heat Bed Thermistor
Heat Bed Thermistor
Home Forums 3D Printers and 3D Printing Heat Bed Thermistor
  • #475128
    Enough!
      @enough
      The typical heat bed thermistor …. does its resistance increase or decrease with rising temperature?
      I'm assuming it decreases but I would like to get it confirmed.
      Enough!
        @enough
        #475138
          Yes, I'm pretty sure the standard is an ntc thermistor. Also used for the extruder.
          They are surprisingly accurate.
          Enough!
            @enough
            Thanks, Neil (not Niel as I'm sure you know wink ).
            So a temperature display that flickers from 60 °C to 7000-odd °C is indicating an intermittent short rather than open circuit.
            #475200
            duncan webster 1
              @duncanwebster1
              depends how it is wired into the circuit and what is measured. If it is connected Vcc-thermistor-fixed resistor-ground then as the tem goes up, the thermistor resitance goes down so the voltage at the thermistor-resistor joint goes up, and if te thermistor goes open circuit the voltage goes to zero.
              However if it is the other way up, the voltage at the joint goes down with increasing temperature and goes to Vcc if the thermistor is open circuit
              #475210
              Enough!
                @enough
                Certainly ohm-meter measurements, with the thermistor plug disconnected at the PCB, indicate an intermittent open-circuit. Moreover that's the failure mode I'd expect from a constantly flexing cable. There's no visual sign of any short.
                So I think your explanation has it, Duncan – thanks.
                Edited By Bandersnatch on 26/05/2020 22:31:52
