Rob, Andy
Thanks for the comments, I also agree that the jaws should be reversible but the shape of the jaw outer ends look square to me rather than tapered to grip when reversed. It looks as if the jaws will not completely centre when reversed and the cowells doesn't have a lot of clearance for jaws that stick out beyond the chuck body. OK if I can keep it within the gap but could be a problem if the chuck or my adaptor is a little long.
Terry, all good comments but I can't agree with not checking and removing the burrs if present or indeed breaking corners if they have been left sharp.. Both faults are quite prevalent on some of the cheaper items available these days and apart from causing tightness and possible jamming, they are very good at giving a false impression of a "good fit". Unfortunately, when production times are tight removal of them is often the first thing "forgotten".
I wouldn't advocate removal of metal from any mating faces and always use a touch of engineers blue to identify the "tight" areas, surprising how often I find them to be in the corners of the jaw slides or even on one chuck from burrs left by cutting the idicator rings in the front face.
I am not complaining as I enjoy the very reasonable prices we can get usable tooling for these days with just the simplist of remedial attention.
Best regards
Keith
