HB961 Digital Readout
  • #556866
    Roger Stanton
      @rogerstanton79412
      Hello, My first post here, sorrry if its in the wrong section.
      I have a HB961 digital readout and Ive tried for a few hours to locate an English datasheet or user manual without success, can anyone point me in the right direction or maybe supply a link or a PDF.
      Thanks in Advance
      Roger.
      Roger Stanton
        @rogerstanton79412
        #556927
        Steviegtr
          @steviegtr
          Is it a raster table counter. If so try this in a foreign language but all there.
          Raster table counter pdf
          Steve.
          #556986
          Roger Stanton
            @rogerstanton79412
            Hi Steve, Many thanks for the datasheet, I can get some info' from it.
            When I ordered it I asked them to enclose a datasheet, which they did, but it was in Chinese!!, an order coming from the UK, beats me.
            If anyone has an English datasheet I would appreciate a copy please or a link to one.
            Best Regards,
            Roger
            #557025
              Posted by Steviegtr on 03/08/2021 22:36:02:
              Steve.
              DeepL seems to make a reasonable job of translating that
              … here’s the first paragraph:
              Input signal: mechanical contact, pulse (low: -30V~+0.6V high: +4V~+30V)
              – External signals: photocell, mechanical contact, inductive sensor, encoder
              – Output voltage for sensor supply: 5V DC, 24V DC 30mA – Possibility to set A ratio, B increment,
              initial value C and change of decimal point.
              – Saving the set parameters in case of power failure.
              – Set of 14 output relay modes
              – 3 input modes including ascending and descending counting, counting
              with phase difference accounting (raster form)
              Ref. https://www.deepl.com/translate
              Edited By Michael Gilligan on 04/08/2021 16:30:24
              #557039
              An Other
                @another21905
                Hi Roger,
                On Amazon, there is some limited data for this device, and if you scroll down there is a section marked 'Reviews with Images' – this includes a tiny two page data sheet in 'Engrish'. I was able to save this image, paste it into a LibreOffice document, then enlarge it to A4 page size. Naturally this ends up rather indistinct without further processing, but it is just readable – may be some help.
                The first part of the 'chinese' document mentioned above is actually Bulgarian, and can be simply copied and pasted into Google Translate, when, as mentioned, it produces a reasonably intelligible output – Ii did try to copy it into here, but although Google produces a fairly well ordered text which is not difficult to read, it loses the formatting when pasted into this message, so difficult to read here.
                #557056
                Roger Stanton
                  @rogerstanton79412
                  Hi Michael and An Other,
                  Many thanks to all, I've now have enough info' to get the unit programmed.
                  Regards to all.
                  Roger
                  #557219
                  Jacques Van Damme
                    @jacquesvandamme27160
                    Hi Roger,
                    You can find the English user manual of the HB961 digital readout on this link:
                    HB961 counter
                    In MEW 305, the recent july 2021 issue, page 26, you will find in my contribution how to connect it with a wire encoder. I used it for a DRO for my Myford ML7R lathe, one for the X-axis and one for the Y-axis. They work fine.
                    Best Regards,
                    Jacques
