Posted by Ronald Morrison on 08/01/2021 00:23:06:
I've found it easiest to just remove the nut holding the tube to the feed mechanism and get it started into the tube, the thread the nut back where it belongs. Once started you can just release the feed and push the filament down the tube.
Ronald, I'm a newbie to this as well, I find that it's best use the direction of curve of the filament and also cut the filament at a sharp angle helps no end. Mines an Ender 3 Pro.
Bob R, I did the same and I'm quietly getting my head around Fusion 360. My first prints were a set of holders for my Multifix tool holders, design on Thingiverse, since then I printed adjusters for the X and Y belts amongt other things. My attempts at a tool tip holder to go on the board with the Multifix worked out ok as well…
I did have a problem with loose screws on the preassembled X axis cross bar causing the setting of the bed to be a nightmare, this was compounded by loose adjusting screws under the heated bed. It took it all apart and put some slightly longer screws in the X axis cross bar as there was a bit of unused thread and Loctited the adjusting screws under the bed, I also change the rubbish springs for a set from ebay (from I_jest-you_not, andylaw1974@hotmail.co.uk) which has now made it much easier to set up and stabalised the bed.
Lots of frustrating fun, a steep learning curve indeed!
