Rod, can you do the following:
1. download a pre-designed file set from Thingiverse.com, (file is in stl format)
2. load a slicer program like Cura to your PC (Cura comes free with the printer if you buy a Creality one like Ender 3, not sure if other makers give out a free slicer)
3. follow the online tutorial for the slicer, or a yout ube video on how to use it and open the stl file, position it in Cura, and slice it, generating a g-code the printer can read
4. put the g-code file made by the slicer program on a micro SD memory card
5. Load the memory card to the slot on the Ender 3 controller
6. Select the file with the controller, push start.
If you can do these things and do basic allen wrench assembly on the machine itself, you can run an Ender 3 3D printer.
Myfordboy has some great videos on yout ube also, for both Ender 3 printer and Elegoo resin printers, and others.
Edited By Jeff Dayman on 11/12/2020 17:30:14
