Although the brass piston and bronze cylinder have fairly similar rates of expansion (brass slightly greater), the metals obviously work ok. Rather than oil or graphite, the best thing before a run is a wipe with a paper towel, there is a small amount of gunk left from burning meths.
I,m sticking with steel cylinders, and cast iron pistons, this combination has a lower coefficient of friction than the copper alloys.
Does the piston pass the test of sliding through the cylinder under it's own weight, then almost stopping if the end is blocked.
Ian S C
