Harrison used four anti-friction devices for diffferent applications. These were:-
1 Use of loaded wheel material–oily woods in segmented wheels with radial grain
2 Anti friction wheels- pairs of plain edged wheels seperated horizontally with the shaft sitting on top of both wheels
3 Anti friction arms- two long arms ( about 12″) with radiused ends, shaft sits in the notch between two arms, counterbalenced and sprung to allow arms to oscillate over a small angle- used on H1 on the axles of the inertial arms.
4 “Rollers”.
The idea of the wheels (2 + 3) is to reduce friction by using mechanical advantage. Imagine that you have a 1/16″ shaft resting on a 3″ plain wheel with plain bearings with some friction u. When you turn the shaft 1 turn the bearing shaft rotates by 1/48th turn so the friction is u/48, a large amount. However there are two plain wheels at each end of a horizontal shaft so the overall reduction is u/12 but still a great advantage and totally in keeping with the concept of no lubrication. So the principle emerges that you get a friction reduction of vr/4 with four wheels where vr is the velocity ratio i.e. the ratio of the shaft to wheel.
You stop axial movement on the main shaft by turning a short taper to reduce the diameter to the wheel contact section so the shaft is centred between the cones, the turned down diameter in contact with the wheels being the smallest that you can get away with!
The only currently made anti-friction wheel device that I know of is the prop balencer made by SLEC. The same idea can be used for loco wheels or motor rotors. There is a single wheel bearing on a tumbling barrel in the Stott Park Mill.
The roller bearing is very different to the anti-friction wheels, in the roller bearing the details of the roller constraint set the frictional losses however lateral shaft constraint can follow the concept of cones as above.
Alan
