I recently acquired a Harrison Universal Milling Machine, which seems to be a real beauty, however there are a couple of questions I would like some help with.
1 there appear to be some feed gears missing and I dont know what they should be, also the manual dosnt state what feed speed gears you would achive with each combination.
The ones I have are 59T 52T 43T 22T 29T. I can see that 59 and 22 are a pair as are 52 and 29, I dont know what 43 would combine with and what feeds I would be able to get.
2 the machine has 3 motors, main spindle motor 2HP, feed motor 1/8HP and coolant pump 1/8HP. All are single voltage 380/440v 3 phase and there is contactor/zero volt switchgear.
I know I need a 240v single phase in to a 415v 3 phase output invertor. Having talked with a well known Invertor supplier in Nottingham it seems I need to either wire the motors directly to there own invertor or use a particular type (described as MA5 plug & play) so the existing wiring and contactors can be used.
Can anyone tell me if this is correct as its an expensive option
3 Does anyone have an easy way of cleaning out the coolant tank or is that a waste of effort?
