I have recently acquired a new-to-me Harrison M300 lathe. It comes fitted with a 3-phase 2.2 kW motor (can be wired star or delta) and I plan to fit with a suitable VFD. The M300 will replace a Boxford model C (now available for sale) and a superior Denford Viceroy TDS 1/2 PCS (the model with powered cross feed) in due course. However, I digress.
I'm looking for comments on the following options.
Option 1: 2.2 kW motor and VFD
Looking at the specification for 2.2 kW output VFDs it would appear the input current can reach about 24 A. This seems rather high but I'm guessing it is maximum inrush current and/or transitory overload. It wouldn't surprise me if many users of cheap import 2.2 kW VFDs use a regular 13 A fused plug and bearing in mind my lathe will be used for light duties only (I bought it for features, rather than throughput) I could possibly do the same, maybe tweaking the VFD configuration. If this didn't work out, I could get a 32A socket fitted but this lacks some flexibility for me as I occasionally need to move machines around in my home workshop.
Option 2: 1.5 kW motor and VFD
Another option I have considered is to fit a 1.5 kW motor (I have no shortage of spare motors from 370 W to 2.2 kW) and fit a smaller VFD. My preferred drive (WEG CFW300 IP20 1.5kW 230V 1ph to 3ph) has a maximum input current of 16.1 A and I'm reasonably confident this will run from any 13 A socket given my use-scenario. This will down-rate the capability of the lathe but most likely exceed my personal needs. If it proved inadequate I could refit the 2.2 kW motor and replace the VFD. That would prove expensive.
Option 3: 1.5 kW motor (trial) and 2.2 kW VFD
This leaves me with the final option: to fit the 1.5 kW motor to assess performance using a 2.2 kW VFD. The 2.2 kW VFD is marginally more expensive than the 1.5 kW option. The 2.2 kW VFD would of course be configured to match the 1.5 kW motor and I assume (but do not know) it would run without problem on a standard 13 A plug as per option 2. If the motor output power proved inadequate for my needs (unlikely, but possible) I could refit the 2.2 kW motor and go to option 1.
