Harrison L5 Oil level
Home Forums Workshop Tools and Tooling Harrison L5 Oil level
  • #183096
    nigel jones 5
      @nigeljones5
      I have just been given a very good L5.The manual says there is a sight glass for the headstock oil level but I cant see one. How do I know how much oil should be in there? Can it be drained? Thanks
      nigel jones 5
        @nigeljones5
        #183098
        Tony Ray
          @tonyray65007
          Fizzy,
          Can you identify approx which period your L5 was made ? have a look at L5's on lathes .co.uk. No obvious sight glasses on the images there but perhaps your manual and machine are from different iterartions. I suggest also that you join the Yahoo Harrison forum? My later Harrison has drain plugs so I would expect to find a similar arrangement on yours.
          #183100
          Manofkent
            @manofkent
            The oli level glass is at the back of the machine – sort of above the motor behind the headstock – and is combined with the oil fill and drain on my L5. The L5 is an excellent machine in my (biased) opinion…
            #183111
            Robbo
              @robbo
              As shown here:
              #183123
              nigel jones 5
                @nigeljones5
                Thanks – so its behind the headstock, the one place I cant see as the lathe is butted up against a wall. Anyone any idea of the volume of oil required or a makeshift dipstick reading from the fill hole next to the gear levers? From what I can gather its late 1950 construction.
                #183133
                  If no-one else will say it, I will. You jammy git!
                  Jon
                    @jon
                    From memory cant recall buying more than two litres of ATF. Nearly all leak.
                    Newer 11" and 140 had sight glass about 7/8" at front of head stock right hand side under speed plate, fill to horizontal line half way up. Newer M series under the chuck/spindle about 5/8".
                    #183176
                    nigel jones 5
                      @nigeljones5
                      Neil, just to add insult to injury, I might now decide to machine the full set of Speedy castings I was also given (many thanks to my generous uncle David for both).
