Harrison L5 1953
Harrison L5 1953
Home Forums Model Engineer & Workshop Harrison L5 1953
  • #155128
    Ron Hancock
      @ronhancock63652
      Hi can any one help me please.
      I am trying to remove my 3 Jaw chuck to fit a 4 jaw.
      I cannot seem to be able to undo it.
      It is a 1 1/2 thread 6 tpi it says in the instruction Manuel.
      I had tried holding the shaft on the Left side and Tapped the Chuck key but the shaft just unscrewed on the left.
      Is their a way of Locking the shaft so you can unscrew it please.
      The book is useless for info nothing to tell you how to change it.
      I have the feeling its not been of in many years.
      Ron
      Ron Hancock
        @ronhancock63652
        Chuck removel
        #155131
        Bob Brown 1
          @bobbrown1
          I would place a block of wood on the bed to protect it and clamp a piece of bar in the chuck in between the jaws at right angles to normal and then hit the bar with a nice large hammer, copper/hide would be my hammer of choice but any thing reasonable will do. Do not tap it hit you are knocking in a panel pin more like you mean it a sharp hit.
          #155136
          Nigel McBurney 1
            @nigelmcburney1
            On no account use the gears to lock the spindle,a strap wrench on a plain part of the lathe spindle will provide some grip,while you belt the chuck,big lead hammer and a really solid blow.
            #155143
            Ron Hancock
              @ronhancock63652
              Thank you guys put 1 1/2 stainless bar in with wood on Lathe Bed sharp couple taps with Hide Hammer it came.
              Tried first using an old large chuck Key as ir had 3/4 inch bar in it.
              Clamped in vice with the handle between the jawes it Bent but stainless did the trick.
              thank you
              Ron
              #155144
              Bob Brown 1
                @bobbrown1
                Glasgow spanner works again!laugh
                #155145
                Ron Hancock
                  @ronhancock63652
                  It sure did Bob was thinking it would never come of
                  Ron
