Decided to finally stop watching YouTube and finish something (for a change). Was feeling a bit idle so I chose a nice easy project – an MT1 slitting saw arbor for my EW lathe. I had [some time ago] purchased a few blank MT1 arbors and turned the body and cap a week or so ago, so I thought it would be a fairly quick job.
The body is a chunk of free-cutting mild steel I'd bored to fit outside the MT1 blank arbor and Loctited onto it. Today I just had to fit the cap and drill through and tap the body for a lock screw. I drilled through the cap no problem but as I entered the end of the blank arbor behind it, I started to get severe chatter.
I decided to try a larger drill but the chatter was even worse. The end of the arbor had been chemically blackened and since I hadn't turned the arbor body itself (but the sleeve) I started to wonder if I had some very odd material and had managed to work harden it or something similar. A quick cut across the arbor face into the blackening however didn't reveal anything odd and it cut OK. I tried drilling again but the drill was by now really leaping around.
Something clearly wasn't right, so I removed the work and had a good look under the light. I could see a shiny bit and the end of my drill didn't look too good either. The end of a sharp (and hardened) pick found that the area around the hard bit could be 'dug out' and two small holes appeared either side of the shiny bit. I was then lucky, as with some thin nosed pliers, I managed to pull the villain out. A piece of 3mm drill, broken off in what I assume was the centre hole. Once removed, I was able to drill the arbor without too much trouble, although the material still seemed gritty and I didn't really get nice curly cuttings (but the drill had probably had it's edges dulled).
I then tried to tap it M6 and found that I just could not turn the tap. Given the problems drilling the arbor, I started to think the body material really was something odd. Fortunately, I decided to go and have a cuppa and think about it. Now when I tap things, I usually just look up the tapping size in Zeus or Tubal Cain. This time I hadn't bothered, as for metric (and I'm mostly using BA) I have an inexpensive set of taps (and matching tapping drills) from Lidl The drill with the 6mm tap was 5mm. Stopping to think about it, that sounded a bit small. Sure enough, Tubal suggested 5.3mm (at 65%) for a 6mm coarse thread. So I drilled out to 5.3mm and now I could just about tap it (although not as well as the free cutting steel I've grown used to).
I've now checked all the drills supplied with the set (Powerfix Tap & Wrench Set M3-M12). All of the tapping drills are smaller than those given as being 85% engagement by Tubal. This may explain why I managed to damage my thumb tapping some fairly thin plate M8 yesterday (I used the drill supplied [6.8mm] when a 7.1mm would have been much easier.
I've finished the slitting saw arbor but decided to stop there whilst I was still ahead! I'm sure the broken drill bit was just bad luck but I should have been much smarter thinking about the tapping drill supplied in the set. Always dangerous to make assumptions.
IanT
