Hardening ss
Hardening ss
Home Forums Materials Hardening ss
  • #713060
    Jonathon MC
      @jonathonmc86670
      I have a new made in England Stanley which I use for bookbinding. The blades are so soft I get through one a night. Although I do sharpen them it has caused a few problems. Is there a way I can harden them please?
      Cant send photo but they are marked no1992 and 11-921,if that helps! Thanks very much.
      Jonathon
        Stanley’s own solution to the problem appears to be this:
        https://www.stanleytools.co.uk/product/0-11-800/stanley-fatmax-carbide-utility-blade-pack-5
        … but I have never used them, and frankly I am rather wary of the the description on that page
        made from tungsten carbide coated carbon steel and stays 10x sharper for longer
        Edit: __ to be clear: Tungsten Carbide Coating is, itself, reasonable enough … it’s the usefulness of putting it on a sharp cutting-edge that doesn’t quite convince me.
        https://kermetico.com/coating-materials/tungsten-carbide-wc-co-coatings
        #713087
        Nicholas Farr
          @nicholasfarr14254
          Hi Jonathon, I would think they wouldn’t be worth the time and cost of trying to harden them, and there is always the risk of making then brittle, which would make them easy to break when in use. These are hardened and tempered, which is done in a controlled process, which I doubt you would achieve at home. Buying them in packs of 100 they cost less than 4 pence for ten, e. g.  https://www.amazon.co.uk/Stanley-1992-100-Knife-Blades/dp/B0001IW8S8/ref=sr_1_25?keywords=stanley+knife+blade&qid=1707462711&sr=8-25
          Other places sell them at a similar price. I have sharpen them myself when I’ve run out, but they don’t keep the edge for very long.
          Years ago in my old job, we used them for cutting 30″ wide and about 1/2″ thick reinforced rubber conveyer belt, and we’d get about six cuts before having to turn the blade, but we didn’t have to pay for the blades.
          Regards Nick.
          #713090
          Jonathon MC
            @jonathonmc86670
            Thanks Michael. I never thought of looking on Stanleys own site!
            #713097
            Jonathon MC
              @jonathonmc86670
              Thanks Nicholas,I ll bulk buy👍👍
              #713104
              Martin Connelly
                @martinconnelly55370
                Ever wondered why they make the blades easy to replace? I have watched carpet fitters at work and they frequently change blades.
                Martin C
                #713113
                DC31k
                  @dc31k
                  What would be the more traditional bookbinder’s tool used for the same job?
                  My guess is that it would just be a good bit of carbon steel, sharpened and honed in the traditional manner as it lost its edge.
                  What I do not know is if it would be single bevel (like a wood chisel) or double bevel (like the Stanley knife blade).
                  If a single bevel item would work, have a look at some of the Japanese marking knives sold for woodworking. They are usually made of good material.
                  Blades of the same pattern are made by everyone under the sun, so you might try some other brands (Irwin, Milwaukee, Rothenberger, CK, etc.) to see if there is any increase in performance. The danger is that they are all made in the same factory and just appear in a box with a different sticker on it.
                  #713125
                  peak4
                    @peak4
                    There’s a number of reviews on the web of different makes, including Stanley 1991,1992, FatMax & Carbide, as well as Milwaukee etc unfortunately quite a few are US based, so those makes might not be available in the UK
                    There seems to be a difference between makes, some are sharper to begin with, some tougher etc.
                    Turn the volume down before viewing this one. 😉
                    Bill
                    #713147
                    Ian P
                      @ianp
                      Wow, less than a halfpenny each, I wish that were true. By my calculation they are 34p each
                      Ian P
                      #713154
                      Chris Gunn
                        @chrisgunn36534
                        Jonathon, Tool chimp have what appears to be the same blades a lot cheaper than Amazon.
                        Chris Gunn
                        #713161
                        Chris Gunn
                          @chrisgunn36534
                          I should have said £15 25 per 100 or 15p each, plus whatever postage,
                          #713269
                          jaCK Hobson
                            @jackhobson50760
                            the std blades should already be hard. They will have been optimally heat treated and it won’t be likely you could make them better.  They are not ss.
                            Why are they going blunt so quick? What are you cutting? What are you cutting on?
                            Maybe stropping the blades will help.
                            #713296
                              I too doubt you could improve the blades. They are disposable, like scalpel and craft knife blades. You can extend their usefulness by wiping them across a diamond slip.
                              Jonathon MC
                                @jonathonmc86670
                                Had n’t expected that much information. I think this type of knife is now traditional bookbinders. Others are so flimsy they can be dangerous. Unfortunately anything from a bookbinders supply would be good perhaps but pricey.
                                Lot of info on here thanks very much
                                Jonathon
                                #713555
                                  The Stanley blades I have are already extremely hard – try drilling one!
                                  I guess the problem is that though hard they are ground extremely sharp by the manufacturer leaving a very delicate edge.   Paper and cardboard are surprisingly abrasive, so the blades wear quickly, and are cheap enough to be disposable.
                                  I’ve not had any success resharpening one on an oilstone, I think because the metal is harder than the grit.  Anyone had any success with other methods?  I’ve not tried diamond.
                                  Jonathon MC
                                    @jonathonmc86670
                                    I could do with a diamond sharpener of some sort so I ll try the blades . Buying new one has got to be simplest way though!
                                    #713560
                                    bernard towers
                                      @bernardtowers37738
                                      I sharpen mine on a diamond flat with the blade held in a razor blade sharpening jig, basically two aluminium plates with a wheel in the middle and a clamping screw. I have to say that they turn out incredibly sharp.
                                      #713710
                                      old mart
                                        @oldmart
                                        If you use these knives and find the blades tend to snap easily in your application, then get the Irwin blades, they are bi, or tri metallic like good quality flexible hacksaw blades and much harder to snap.
                                        #713719
                                        Jonathon MC
                                          @jonathonmc86670
                                          Coincidence-I like Irwins hacksaw blades for that reason.
                                          #713943
                                            The SMEE spark eroder used to be demonstrated by boring holes through Stanley blades.
                                            #713961
                                            Ian P
                                              @ianp
                                              I have followed this thread (and actually posted to it) but only just now realised that the thread contents have very little to do with the title. Stanley (and other makes) of these trapezoidal blades are almost exclusively made from carbon steel. Out of curiosity I tried to find stainless blade and arrived at the conclusion they are as rare as hens teeth, (they do exist though.)
                                              I did find ceramic blades which according to the blurb would last several nights of the OP’s usage (note the finger friendly edge!)
                                              https://www.amazon.co.uk/Slice-10524-Ceramic-Utility-Blades/dp/B0119PP9MI
                                              Ian P
                                              #713978
                                              duncan webster 1
                                                @duncanwebster1
                                                At £6.50 each I think I’ll give those a miss
                                              Home Forums Materials Topics
